How to install EGR?
go somewhere else as he hasnt a clue, the egr valve is on the bottom of the inlet manifold under the throttle body , to run als you need the sas valve which bolts to the side of the head and connects to the upper throttle body pipe and the exhaust manifold .
If you have a US spec Evo, I assume you have an 8 or a 9. There are numerous threads on here regarding the lack of coding to support true anti-lag on the ct9 platform. A few have made it happen, but that was via open source tuning, not ECUTek. The anti-lag hardware all bolts to the exhaust side of the motor, not the intake side. EGR will not be part of that.
fostytou
338
Nov 10, 2023 12:55 PM
phabaznbro
Apr 18, 2008 08:44 PM
