Radiator fluid turned red
Old Sep 8, 2013 | 08:44 PM
cool_as_crap's Avatar
My radiator fluid turned red, and there is a build of up red flaky material at the radiator cap. Has anyone had this problem? I'm going to flush the system tomorrow and see if it comes back. Am I completed ****ed? Or maybe just need a new radiator?
Thanks in advance!
Old Sep 8, 2013 | 09:14 PM
djdnav's Avatar
It means someone put non-distilled water in there. You should only use distilled water otherwise the whole system gets rusty and gross.
clubEVO93's Avatar
Sounds like rust. I would flush it ASAP! And find the rust spot if it is. Let us know.
Old Sep 9, 2013 | 10:54 AM
I flushed it with a few gallons of distilled water and refilled it with coolant. When I poured the coolant, it turned brown again without starting the car. It isn't milky, its more if a sandy mist.
Old Sep 9, 2013 | 12:07 PM
djdnav's Avatar
its gna do that unless you flush it a few more times... basically all the pipes have a rusty finish on the inside now. If you flush it again in a month it'll be cleaner, and more so the next time.
LancerOZDude
Lancer Troubleshooting
Oct 7, 2014 03:50 PM
luislm21
Dec 28, 2013 09:38 AM
JPsRalliart
Jul 2, 2013 06:04 PM
smsevo8
Jan 10, 2012 10:26 AM
evo_tiago
Feb 18, 2009 07:15 PM
Quick Reply: Radiator fluid turned red
