8 or 9 transfer case.
yeah i understand that but mine t case cracked from a rod hiting through the block and cracked my case, can i just get a non acd case and use it on my evo 9 or put the acd thing from mine t case on the non acd one? nd yes im
I did some searching awhile back and found out that the acd pump cannot be removed on a acd tcase, otherwise it becomes fwd. Only way to get rid of the system is to get a non acd tcase, which are rare to find nowadays. Im sure you can find a replacement case in the sale section (or ebay where you dont know if it has a death wine).
Im not sure if the cases are interchangable
How bad is the case cracked on yours? Can it be welded?
it can be welded but the rod hit pretty hard and bent the thing inside like when u take off the housing the next piece is bend it it cant be replaced it would need that new piece... it sucks this **** is expensive
WTB[SouthEast]: WTB: Evo 8/9 acd transfercase
_des_
Oct 29, 2016 02:43 PM
[WTB] Evo 8/9 Stock radio
overdrive1
Aug 27, 2016 09:12 AM
vipevo9
10
Feb 4, 2014 05:21 AM
