Transmission and TCase install question!
Dropped my transfer case and transmission out of the car a few weeks ago. I should be getting both back from ShepTrans on friday
I already purchased all new OEM fluids and a new DP donut gasket.
Has anyone had any prior experience with the installation and know and more parts I need to purchase for it?
Even some tips would be nice lol,
Thanks
- Phil
Thanks
- Phil
Did you take the trans and tcase out? If yes pretty straight forward putting it back.. few threads on here about it. I would make sure you have the orings for the tcase few extras just in case.
Good article around the trans portion
http://www.evomoto.com/tech_articles..._article_id=27
I've never removed the tc so no help there but I recently did a clutch on a 5-speed. I thought the install was going to be difficult. So before hand I did four things.
1. Took a Dremel to the four studs on the end of the tranny and cut them off leaving enough for the thickness of the mount, nuts and a bit more.
2. Put the transmission in neutral and removed the control housing.
3. Dropped the engine as much as possible while avoiding smashing anything against the fender
4. Moved the engine forward about an inch. I did this by inserting the scissor jack that came with the car vertically ahead of the transfer case and in between the block and subframe.
It would be interesting to have someone post here who has watched a mechanic at an Evo pro shop and tell how they do it. The only thing I have seen done by a pro is this film on youtube.
As you see, he drops the subframe but I don't believe that this is the usual practice.
the small o ring on the tcase between where it mates to the tranny is the most important thing.
also if u loosened your subframe remember to retorque it when u finish the install.
proper tcase filling is another thing.
also make sure when u put the axles back into the tcase that you dont jamb it in there and pinch the tcase inner seal. you will have a leak thats a huge headache.
rydogg008
May 23, 2016 03:27 PM
KozmicMotorSpts
EvoX 'For Sale' Engine Internals and Drivetrain
Dec 6, 2013 08:27 PM
getek20
11
Apr 7, 2011 08:21 AM
