Quiet exhaust
Quiet exhaust
I have a full custom tbe from previous owner no resonators and a magna flow muffler. This thing is loud. My neighbors hate me, cops hate me etc. Now it being 2013 are there other quiet exhaust solutions? When I searched all results from 2006. I honestly don't mind the noise.... Because I don't want to sacrifice power for noise. I only want it to idle quieter so I don't wake my neighbors. I'm frequently coming home in the 12-4 am range. I will be running tp and dp too.... No cat. I'd also prefer an exhaust that was full turbo back over a cat back.
In my best opinion, you should get a down pipe and then a resonated test pipe and then a catback with 2 resonators welded in. It should help. I have a 3"DP, Gutted HFC and an AMS catback with one resonator installed. It idles nicely and not too loud. It is only loud when you hit the gas hard. Cruising around, it isn't very loud at all. I hope this helps.
I'm in the same boat, previous owner had a 3" TB exhaust installed. Neighbors don't say anything, but I can only imagine.
Since then I've swapped out the test pipe for a resonated one, helped a tad but not enough.
My next purchase will be this part from STM to see if it gets it where it needs to be...
http://www.streettunedmotorsports.co..._resonator.htm
Good luck!
Good luck!
110 threads on this already...Tanabe touring medallion is really quiet (93db). As stated resonators dont make it quiet---think about a Decent hfc instead, by decent I mean with something other then 100 cell count. for the 10-hp your giving up you ears and neighbors will thank you.
i used to have a full turbo back.. downpipe, testpipe with a greddy ti (rolled tip). sounds awesome but it got old after driving the car for 4+ years. fast forward to this year, i decided to get an RRE(road race engineering) stealth catback. it has 2 resonators and a magnaflow muffler. it is custom made but i believe you can have them make you one by just telling them what year make & model you have. its a big improvement as far as noise and drone go. i didnt even know that my 6 puck was loud till i put the rre catback on. 200 bucks well spent if you ask me. might look into getting a resonated testpipe soon.
my first catback was the greddy evo 2 i have to change the resomator at the midle because is restrictive and install a magnaflow resonator ,with test pipe at idle is 92db , later i get the hks sport exhaust wth milspec 100 high flow cat and at iddle is 83 db , about performance is about is about 5 hp difference .
but is 10 pounds less diference in weight.
theres a slight chance i may let mine go for the right price, since it is pretty heavy for a track car.
