Zeitronix ZT-2 MAP shows vacuum when exposed to atmosphere?
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Installed Zeitronix ZT-2 with their supplied MAP sensor for boost readings, and I'm getting some odd feedback. Maybe I haven't had my morning coffee, but tell me if this is normal:
Exposed to atmosphere, engine off, reads -10.8/-11psi of vacuum. Connected to reference vacuum line, reads -16 and lower psi at idle....I'm not going to believe that for a minute with GSC S2s
![Zeitronix ZT-2 MAP shows vacuum when exposed to atmosphere?-diecymch.jpg](https://www.evolutionm.net/forums/attachments/evo-general/332820d1683221609t-zeitronix-zt-2-map-shows-vacuum-when-exposed-atmosphere-diecymch.jpg)
![Zeitronix ZT-2 MAP shows vacuum when exposed to atmosphere?-rlaycl4h.jpg](https://www.evolutionm.net/forums/attachments/evo-general/332821d1683221609t-zeitronix-zt-2-map-shows-vacuum-when-exposed-atmosphere-rlaycl4h.jpg)
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Could the wiring be incorrect?
Zeitronix Pin 1 Red goes ECU Pin 25 (12V Switched Power Supply, or any other 12V source)
Zeitronix Pin 3 Green goes ECU Pin 58 ( Tach Signal)
Zeitronix Pin 7 Black goes ECU Pin 26 (Chassis Ground, or any other ground)
Zeitronix Pin 11 Brown goes ECU Pin 92 (Sensor ground)
Zeitronix Pin 10 Grey goes ECU Pin 84 (Throttle Position Sensor Signal)
Boost Sensor
Boost Sensor Green cable goes Zeitronix Pin 4 Orange
Boost Sensor Red cable goes Zeitronix Pin 6 Yellow
Boost Sensor Black cable goes Zeitronix Pin 11 Brown
Boost Sensor
According to Zeitronix -
50 psi sensor: pressure = 12.5 * voltage - 20.95
75 psi sensor: pressure = 18.75 * voltage - 24.075
So if the ZT-2 controller is software set for the 5 bar, and if the circuit has 0.7V, I'd end up with the 3.5 bar MAP generating a signal equivalent to -10.95psi. I won't have my serial-usb adapter till Wednesday so I'm going to have to live with it until then and I can dig around the software.
Did some further testing yesterday with a friends ZT-2 box.
1 - I have the 2009 model vs the 2010+. This is what I get for not learning the difference ahead of time, and then not asking about it before buying it on the F/S Forum.
2 - When the 2010 model is plugged in, I can manipulate and calibrate the boost sensor to read 0psi at atmospheric, no problems at. With the 2009 box, it detects the boost sensor (it's getting the reading) but it isn't allowing me to calibrate it at all.
I'm going to shoot Zeitronix an email and see what the difference is. I'm tracking the 3.5 bar map sensor is supported by both models.
Originally Posted by Zeitronix
You may have old 2004 Zt-2 if this function is not available.
Blak94GSX
Evo X How Tos / Installations
21
Feb 4, 2015 03:02 PM
Dynotech Tuning
13
May 24, 2012 09:37 AM
tboboy
Aug 7, 2010 03:39 PM
TTP Engineering
EvoX 'For Sale' Interior Styling
18
Dec 1, 2009 12:45 PM
