New Clutch and it engages RIGHT off the floor
Old Dec 18, 2013 | 11:45 AM
black_beauty's Avatar
I just had a new clutch installed in my car and the engagement seems way too close to the floor. Is this bad? I plan on doing the clutch drag test but haven't found the link to it. Thanks
Old Dec 18, 2013 | 11:55 AM
tkklemann's Avatar
No, as long as it isn't dragging you will be OK. Personally for me this is the way I like it set up on my car because if you use two step launch, as soon as the switch is disengaged the clutch is already grabbing or right after..
Old Dec 18, 2013 | 12:55 PM
Raptord's Avatar
Drag test is easy.. Find flat, level ground, 1st gear with clutch fully in and gradually increase throttle until you hit 2-step. Car shouldn't creep forward. You can be even more thorough by disabling 2-step temporarily to allow you to rev up to 7k.
Old Dec 18, 2013 | 01:33 PM
Kracka's Avatar
Make sure the clutch was bled properly and there is no air in the hydraulic system. If that checks out, adjust the CMC rod.
Old Dec 18, 2013 | 06:27 PM
1UpMoto's Avatar
No need to bleed it when replacing the clutch.....
The_Police
Apr 6, 2016 07:05 PM
URNVS
May 30, 2013 02:59 PM
wicked white14
May 6, 2009 03:51 AM
madmax4499
19
Nov 11, 2007 08:51 AM
KazzEvo8
11
Sep 12, 2006 08:53 AM
Quick Reply: New Clutch and it engages RIGHT off the floor
