Track wheels on street?
Anybody ever have experience with using "track wheels only" on the streets? I'm looking at getting these BBS wheels,but they're specifically for track...Could this mean the thickness of the wheel won't stand up with the riggers of street roads?
http://www.bbs-usa.com/race-wheels-d...?CLID=83&WF=12
Personally I would steer clear of these very speciailized race wheels.
Its likely that they are race wheels only due to the 3 piece design & the constant re-torquing required of the face bolts
Keep in mind 3 piece wheels have a gasket sealer between the wheel face & the barrel so air leaks are possible if everything is not correctly seated or torqued
A lot of Porsche owners run these on the track & you know how an@l they are
With that said, it probably OK to run them on the street as long as you dont beat on them too much
Curious if they fit w/out spacers
You should be fine depending on the tires you plan on using. Any wheel will have issues if the tires don't have enough sidewall strength. I ran racing wheels and tires all the time on both track and street applications.
Parikh1234
Jun 6, 2008 12:17 PM
