Evo Rattle.... Yet another thread..
Tried to see if anyone had a solution or some knowledge, but the videos I've seen aren't the same noise that I have...
The Car drives perfect fine. There's Oil in the motor, and fluids in both Trans and TC. I noticed the sound the other day whenever she went to change gears I hear this crazy WHIRL sound like a bearing or something.... Car drives fine, I even had her WOT real quick and runs fine with no hesitation. However the noise can be heard on Idle.
When I lightly step on the the clutch, the noise in gone. I also don't hear it if it's in gear and driving only between shifts and idle.
I also had her drive down the street and take it up to 5K press and hold the clutch and you can hear that grinding/whirl sound as the RPM's drop then as it idles you hear the thud thud thud, as you can hear in the video.
Last night i went underneath and popped the TOB off the wave clip and sure enough you STILL hear the sound with the TOB not touching the wave clip.
I'm stumped and can't figure it out. Yes my twin is very noisy since day 1.... Any help and suggestions will be great. It has over 1500 Miles on the Twin. No signs of any tranny/tc issues no metal shavings in the oil, nothing that I can find out without tearing it apart.
Video below.
Video below.
Also just drove it right now, on Decel it makes a crazy sound definitely wasn't there before. This noise just started the other day.
Exedy Twin... It's just odd the Trans is New, the TC is New, fluids are new. The Car hasn't been driven hard.
It sounds like somewhere within the clutch something isn't aligned to the tranny? Like one of the clutch disk teeth got jacked up? (I'm just taking wild guesses here)
I'll drain the fluids this weekend and check for shavings. Drove the car yesterday over a hour worth of stop and go driving and the car drives and clutch engages perfectly fine. Both low and high rpm's
I know I know, I probably shouldn't drive it like that as I can be harming the car. I do have spare parts to replace if something fails.
I haven't check the car out today but I will tomorrow.... Started it up today to see where the noise is more directed to... from the Trans or Block... and it does sound like it's coming from the Block.
But how would applying toe pressure to the clutch eliminate the noise? I'm starting to believe I may have ran into Crankwalk =\
Even if let's say it's ROD knock, it would do it consistently,...... tomorrow I'm going to drop the pan and see what I can find out underneath
heel2toe
30
Mar 15, 2016 12:54 PM
smokedmustang
103
May 11, 2006 08:19 AM
smokedmustang
23
May 9, 2006 09:40 AM
zstryder
28
Aug 15, 2005 09:19 AM
