Safest way to go back to stock ecu?
How do I go back to a stock ecu? I currently have an apexi power fc stand alone when I bought the car but Its not working out for me. I bought an ecu off the forums, so what's the safest way to go about this? Already ordered a tactrix cable and evoscan software. Getting a afr installed soon, cuz I know that's helpful. Help me out please. Thanks
hook it up, pull the rom ID, then head over to the ecuflash subforum here. Find the correct TephraV7 rom and start with that. You will need to build new maps for your car depending on mods etc... You will also need to adjust some things (i.e. immobilizer hex) to get it working. If you dont have access to a tuner you are going to need to do alot of reading in the ecuflash subforum, but its all there, everything you need to diy.
