sharing my odd power steering pump pulley failure
like the title says,
finally put the car back together, getting ready to sell it, turn it on and start tuning the idle/ start up, then i start hearing metal to metal contact. i got out once it idled, and noticed my power steering pump pulley was shaking like a cracked out bobble head doll. shut off the car and the pulley is seized against its own bracket. already buying another pump so im just sharing this, and also wondering if anyone has had this happen before... quite odd... and pretty depressing... lol here are some pics
I'm getting unusual drag from my power steering lately, so much so its causing a slight idle dip when turning the steering wheel as I'm coasting to a stop. No noise though but you've given me something to take a look at when I get home tonight. Thanks. On a similar note is there an easy way to replace the PS fluid on the car. I was thinking of using two buckets. Have one bucket empty and one filled up with new clean PS fluid. Then put the return hose in the empty bucket and the feed hose in the bucket with new fluid in it. Then whatever fluid it spits out would be replaced with the exact amount of new fluid. Any better ideas of how to do this?
As far as draining/flushing the system, you can either get a turkey baster and suck out the fluid from the reservoir, top it off with fresh fluid, run the car for a second or two, shut it off, suck out the fluid again, top off and repeat a few times.
You can also drain it by removing one of the return lines if you don't want to suck it out of the reservoir. Make sure not to forget to remove and clean out the filter in the power steering reservoir.
I know u can bend the pulley, when u remove the trans without carefully supporting the engine, it will hit the frame rail and bend when the driverside of the engines dropped but idk know what u got goin on
we did recently swap the clutch, maybe thats what happened? we had a good engine brace cradle thing supporting the engine though... hmmm that definitely is a possibility
[WTB] Aem gauges
minimarine09
Mar 14, 2017 11:55 AM
FS[MidWest]: EvoTuna's Tax Season Partout!
evotuner04
11
Mar 7, 2017 08:19 PM
minimarine09
18
Sep 26, 2013 12:08 PM
