evo wont turn OFF
evo wont turn OFF
for some reason today my evo wouldnt turn off. car sat for 2 months because of radiator. bought a new one and everything is running perfect except the car wont turn off unless i purposely stall it. i mean i can pull the key out and still drive. my turbo timer seems to be dead also, im sure these two are related. please help, thanks
The key should never be able to be pulled out like what you explained. My best bet is that your key cylinder is messed up. The tumblers inside are now junk. I advise you to remove the turbo timer (Not really needed in my opinion) and replace the key cylinder. You might want to check the ignition switch also. Oh, key cylinders can be ordered OEM from any dealership and it will come with a new key. You will have to program the new key to your vehicle. Good luck, I hope this helps.
When you pull the key out is it in the OFF position? Sounds like it isn't....Put your key back in and try and gently wiggle it to get it to go to the off position.
Your ignition may be worn and the combination of your key bitting and wear could be causing this.
Will it let you turn the cylinder to the off position?
sammylew34
Jul 11, 2013 05:32 PM
