Pulling motor
Old Jan 9, 2014 | 02:56 PM
slowonder's Avatar
Pulling motor
Now I need to do the T-belt and clutch on my car and was wondering if I could just pull the motor alone and not with the trans? Without having a lift and being able to drop it all out the bottom like I do cars at work I would rather just pull the engine alone if its possible.
Old Jan 9, 2014 | 05:32 PM
MRolla's Avatar
Yes you can pull the engine out from the top. You will need a engine hoist to lift it out. Just don't forget to undo the tob. But if you do this at work all you should know it will come out the top.
Old Jan 9, 2014 | 05:36 PM
TommiM's Avatar
the transfer case is in the way of one bolt for the block. So you have to remove the transfer case. The next issue is moving the block enough to the pass side to clear the bell housing and clutch assembly. Theres alot more room for the transmission to slide to the drivers than the block, from my experience anyhow. I left the transmission esentially in the engine bay, although it was unbolted and on a tranny jack, just so I could slide it to get the engine out from underneath. Granted, I had the head off so I was able to slide it underneath the car which was on jackstands.
The short answer is yes, you can pull the motor out by itself, but I dont know if it could be done with the transmission completely mounted in the car. That would seem like it would be harder than to just undo the two motor mounts supporting it imo.
Old Jan 9, 2014 | 05:40 PM
Terror Rising's Avatar
It may be possible but probably not worth the effort. As TommiM said you're going to have to unbolt the trans mounts anyway so just go ahead and pull them both. I pulled the t-case/trans out last weekend and am now going to pull the motor so I can work on it while the trans/t-case are getting built. I will be putting the engine/trans in as a unit as I'm sure it will be easier that way.
Old Jan 9, 2014 | 07:37 PM
slowonder's Avatar
no it will not be done at work. if i could knock it out in a weekend i might be able to do it but ive got to much other stuff i want to do to it also. yes i have a picker so thats not a big deal. might just pull them both out then.
Old Jan 9, 2014 | 11:50 PM
Biggiesacks's Avatar
Save yourself the headache and just pull them both together. Trust me it will be easier. In the end it will make getting them back together alot easier with them both out of the car as well.
Old Jan 13, 2014 | 03:13 PM
slowonder's Avatar
ok another question real quick. when doing the wave lock clip ive heard of putting multiple clips in. are they refering to the wave spings? the one on my PP now has 2 wave springs in it. if i buy another and take mine off my pp and put those 2 on the other one is that what they are talking about?
Old Jan 13, 2014 | 05:36 PM
1UpMoto's Avatar
why would you pull the motor to do a clutch and timing belt?
Old Jan 13, 2014 | 05:52 PM
bbong's Avatar
You don't need to pull the motor to do T-Belt and Clutch, do the clutch first by unbolting it from engine and tcase and dropping it down, do your clutch and put it back on.
Then undo the engine mount on the passenger side and on the bottom, slide the jack under the engine (oil pan) put some padding not to damage the oil pan (piece of wood?) and use that to lift that side of the engine up and down, this will give you access to the pulleys, water pump etc. don't add more work for yourself by pulling the engine.
slowonder's Avatar
Well I rather pull it all out the top than drop a trans on the ground on my back then have to do a timing belt job with very little room when I can just pull the engine trans and do it all with as much room as I want
Old Jan 13, 2014 | 05:57 PM
slowonder's Avatar
The few people I've talked to around here said just to pull it all of I have to do both of them. It doesn't really matter what way I do it I have like a month to finish it.
Old Jan 13, 2014 | 05:59 PM
bbong's Avatar
I did Engine + Tranny out the top many times, if you want to go this route, get the engine leveler and it'll come in and out of the bay through the top with Intake Manifold and Alternator attached, but you're just adding more work for yourself, there's no need to do that unless you're doing this because you have abundance of time to waste
Old Jan 13, 2014 | 06:15 PM
slowonder's Avatar
I always have to much time
Going to do the rear end lsd plate fix and head studs. Got nothing but time.
Old Jan 13, 2014 | 06:18 PM
bbong's Avatar
Pulling the Engine:
1) Unhooking the Harness (some places are hard to reach especially by the firewall), stock rails require you to pull it in order to unhook injector harness.
2) Easier to do with 2 people, especially when dropping it in and aligning both sides + t-case or it may get lodged in lower the engine
3) You are basically purging all the fluids (t-case gear, tranny, radiator and engine)
4) Unhooking the exhaust manifold and Turbo
5) Removing radiator and all vac lines + HVAC
* Remember you have to put that all back in too, new oil drain to oil pan gasket, possible missing bolts and screws as it always happens when undoing it all :P
Not Pulling the Engine:
1) Drain Tranny Fluid only and maybe Gear?
2) Undoing passenger side mount
Choose your poison, but I would take the latter one.
Old Jan 13, 2014 | 06:37 PM
slowonder's Avatar
I pull engines weekly at the body shop I work at so I figured pulling it would be easier for me just never done an Evo before. . And still have to drain all of those fluids as I'm doing waterpump and oil change anyways.
Quick Reply: Pulling motor
