e85+dailydriven+oil interval
Lots of opinions when people run ethanol. The accurate way to get fact data in your unique situation is to send a sample of OIL to the laboratory for an accurate answer.
My past experience has been with a premium OIL not a semi synthetic like Mobil 1, and the 100% full synthetic was able to be run 6,000 miles with blackstone lab saying run another 1,000 miles and check back again. Every situation is different so you must do oil analysis to figure it out. Since E85 is harsher on OIL that regular 93 octane pump gas.
After doing some research on the various properties of oil... I have found that mobile one is crap oil... I dont recommend anything less ten 15/40 to my customers based on the fact lesser oils break down in the turbo causeing thrust bearing galling... And leave the bearings unprotected... If you upgrade to zero tick lifters 20/50 bp oil is a great option but with upgraded lifters you could be doing your valve train an injustice... Never drive a car cold on thicker oils as they have vastly higher viscocities at 40*c then at 80... But at temp they flow relatively well and shouldnt cause any issues other then not plumping the lifters... The added shear protection in the high grades is great for turbos. If you run 5/30 or 10/30 and run your car hard then prepare to kiss your turbo goodbye...
All applications are different and some may not experience any issue from thinner oils...
Apagan01, so zrod is a good oil for my set up ? It's a stock motor stock turbo on e85. And I'm in cali so it's mostly warn weather, and the e85.is pretty consistent at 88-89%
I see alot of hate for Mobil 1, but i have personally run it for 140k miles on my evo. When my timing belt tentioner let go at 125k i tore it down and all my bearings looked amazing, the cam journals didnt have as much as a scuff on them. No sign of sludge anywhere. Original turbo had no shaft play and no sign of coking what so ever. I would put more emphasis on using a quality oil filter and proper oil change intervals then on spending mad money on boutique oils.
Even Mobil 1 will tell you not to use any oil when running ethanol.
Why the hell when it comes to engine protection we always want to get the cheapest. The tendency is ill just go to wall Mart and buy the cheapest oil I can find. When the internals of an engine or turbo surely benefit from a good well designed synthetic oil.
http://www.mobiloil.com/USA-English/..._E85_Fuel.aspx
Mobil 1 carries the API SN rating Here is their product guide.
API's description of the SN Certification is as follows: "introduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons, more stringent sludge control, and seal compatibility. API SN with Resource
Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing
fuels up to E85." Source
Jeff not to ruffle feathers here but have you looked at the oil filter test done here? For the price and the much much better protection do yourself a favor.
start buying purolator one filters from advance or wix from OReillys. They do twice the job the om filter could dream of.
Also just one time change your oil to a better full synthetic 15-40 or 20-50. Then do an analysis, you'll thank the members of this forum later and your motor will thank you instantly. Mobile one will never ever touch my car. Also if you look at price, Lucas racing oil can be bought for 20 a gallon and it ****s on mobile one in terms of alcohol compatability, avoidance of thermal breakdown, and film strength.
