Spooling characteristics
Bazing! Took thenpin out of the wastegate and found that with the wastegate attached the flapper still wasnt closed all the waym gave it half a turn and reconnected it and bam shes running like a champ. Thanks for the help!
So did you have same BOV in conjunction with both turbos? I really dont think that it is BOV related. I still think the issue is insufficient actuator spring pressure. But, until we nail down the problem we cant rule possible causes out.
Did you turn your MBC out to its lowest setting so that we can get a read on your actual spring pressure?
Please do as I requested and back the adjustment knob on your MBC all the way out(-) counterclockwise to full soft and do the WOT run. This will give us a read on actual spring pressure. Once we establish the current level of actual spring pressure, this will serve as a baseline.
From that point, we can subsequently go on to adjust(increase) spring pressure incrementally to a point just below your peak boost level. Our aim being to keep the flapper valve from lifting until the last possible moment. This will improve spool significantly which is what you want....right?
As a general rule of thumb, in order to obtain optimal spool on an MBC controlled, internally gated setup, adjust WG spring pressure to a level 2-3# below the peak boost setting targeted on your MBC.
You may, or may not realize that your turbo can be made to spool considerably quicker and therefore reach your targeted peak boost level way earlier if you increase spring pressure by adjusting the actuator rod's overall length even shorter. A half turn is insignificant given the actuator's range of adjustability. So you just scratched the surface.
I also have a IX turbo that I converted to a 20g and I use an 17 psi wga with it. I also took the wga arm and slid it over the flapper then slid it back off. Turned it 2.5 times and then pulled like a mother trucker to get it on. All the research I did said 3 turns but that was too much. With 3 turns and 2 ppl pulling on it I couldn't get it back on the flapper but at 2.5 and a lot of yanking it went on lol. I can hold 30 psi all day long with it set up this way. If all you did was just turned it to where it slides right on then turned it 1/2 a turn to the best of my knowledge and research that isn't even close to enough preload at all.
kpt6
Jan 4, 2014 11:19 AM
