Tcase fluid change
There's a big screw on the bottom of the T-Case, this is to drain it. Then you undo the one on the side, get a funnel with long hose, put it in there, fill it until it starts overfilling or 0.68qt.
Car should have all wheels flat on the ground, not raised.
I usually would still ride it for couple miles and then top it off.
If you don't have a lift, then you have to lower it when filling it up.
Use OEM DiaQueen Gear Fluid
Keep filling it and waiting 10mins as said above until you truely cannot fit anymore fluid in the case. Every transfer case will give a false full reading and you might think it's full but it's not. I think I filled and waited a few minutes 4-5 times before it was actually full and no more fluid could be stuffed inside.
