usdm evo 9 mr headlight
if i buy a usdm evo 8/9 MR HID headlight housing, can i just buy some aftermarket HID kit and plug and play into the housing? I know the OEM setup requires getting the oem ballast, bulb, hardware and it seems hard to find. I was thinking of just buying the MR headlight housing and using a aftermarket hid kit. will that work? of course i will be running it at 4300k and 35watt. thanks
I'm curious about this as well. I have the Evo VIII HID headlights that need new housings and I would like to know if I could do the same thing with MR housing and just switch everything over will work or not.?.?
If you run aftermarket hid kit, you will have a large hole in the bottom of the headlight housing, where the oem ballast goes, the oem ballast has a grommet, that seals the housing, so if you could seal the hole where the ballast goes. you could run aftermarket hids. i would just buy the oem stuff all you need is two ballast and you can bulb off amazon
but wont just using USDM or JDM 8/9 MR headlight WITH
morimoto aftermarket HID kit be alot easier since i dont need to find oem ballast and harness? wont the morimoto or any aftermarket kit come with ballast and harness to connect directly to my non hid gsr evo?
Yes an aftermarket hid kit will be plug and play, if you kept your non hid headlight housings you would avoid having the hole thats in the oem hid housings where the ballast goes in the bottom of the headlight housings, just saying the oem ballast seals the headlight otherwise you have like a 2.5 inch whole in the bottom of the hid headlight housing
Boltz.
Midwest Region
Sep 18, 2011 02:37 PM
carlmalonie
For Sale - Part Outs
12
Feb 18, 2010 10:56 PM
