For ish and giggles
For ish and giggles
To know the background of my car: https://www.evolutionm.net/forums/ev...-evo-shop.html
So over the next several months I'll have to start making decisions on what to do with my car.
My goals would be 600+ whp that handles.
I don't care if it is loud and obnoxious sounding either.
I had a Tanabe Concept G Blue exhaust on my 1st and loved its sound.
So I'd probably at the least want that muffler on the car.
So here is where you guys come in, if you were building a 600+ whp evo what parts would you go with and why?
And before anyone says "search"...look at how long I have been on this forum. I am fully aware and have tons of ideas about the route I may go but just thought it would be interesting to hear all of you guy's thoughts.
Honestly, 600+ is the top end of the EF4's capabilities. The up side to going EF4 is primarily budget related in that you can use a stock frame manifold, downpipe, oil lines, etc. If you're looking to exceed 600whp significantly I would recommend something like these:
http://www.maperformance.com/map-com...p-evo-t3k.html
http://www.maperformance.com/map-sta...i-evo-8-9.html
If you are using pump gas an HTA3586 can smoke an ef4 and I am a huge ef fan (see sig.)
Fuel choice plays a huge role in this decision. If you want 600 on pump an ef4 probably won't get you there. I think the most I've seen was 525 on pump, someone correct me if I am wrong. The HTA3586 can get you well into the 600s with the right set up on pump.
Anyone have any other parts besides a turbo they would go with, since I think I have decided on the HTA35r?
Cams - Thinkning the GSC S2's will work
Injectors - Not sure which ones
Dual pumper - thinking BR one
Exhaust - any 3" piping and I'd like to have the tanabe concept g blue muffler
Clutch - I already have the exedy twin hd
I'd like to upgrade the trans and transfercase while at it.
Also want to upgrade the suspension and rims.
Also, would you go ported stock intake manifold and tb or an aftermarket one?
So that is some of what I have thought of.
