MAP Universal 3" Inline Exhaust Damper
Brilliant indeed. How does the switch work? Hit the switch once and it would open/close completely or does it stop if the switch is released? In other words does it function similar to the Varex muffler?
I have the Varex and it's brilliant.
I usually close it during highway cruising because it kills all drone.
I always keep an eye on the EGT and it doesn't change during open/close.
How do you install it?
Using the provided template you will simply drill two holes into your 3" exhaust (we exclusively use .065" wall tubing with an exact OD of 3.16" which is what this product was designed around) near a connection point. You slide the butterfly shaft through the holes and fasten the aluminum clamp with the included hardware. Install the butterfly plate from the connection point (be sure to use loctite!) and all you've got left is to mount the switch and connect power and ground to get the ball rolling.
Ok so this is designed for a 3" ID exhaust pipe, it says you use a 3.16" OD pipe, How would it go with a 3" OD pipe? Can you tell me the actual diameter of the butterfly valve?
I don't think going into boost should be an option. I see this as a great way to go around quiet neighborhoods and parking lots. I wouldn't consider even driving on anything past 25mph. I think that might be pushing it.
I really want one now!
RallySport Direct
EvoX 'For Sale' Electronics / Lighting / Audio
Nov 28, 2016 03:44 PM
RallySport Direct
EvoX 'For Sale' External Engine / Power
Nov 18, 2016 11:36 AM
RallySport Direct
EvoX 'For Sale' Engine Internals and Drivetrain
Nov 14, 2016 03:32 PM
RallySport Direct
EvoX 'For Sale' Suspension / Brakes / Handling
Dec 11, 2015 09:26 AM
RallySport Direct
EvoX 'For Sale' Exterior Styling
Dec 11, 2015 09:22 AM
