No Start NEED HELP
i didnt see it mentioned, make sure it has gas.
I swapped an evo from stock mapping to tehpra once ... I disabled the immobilizer and the car ran great... Then when i shut it off it wouldnt start back up... I had to reflash it to get it to fire again... Eventually i figured it out that the immobilizer wasn't staying off and would keep the car from starting...
I'm to lazy to read all this so forgive me if i skipped it being mentioned
meckert - All fuses check out okay. Still working on fusible links. Fuel isn't my issue. I'm getting fuel spitting out of the return hose, and I see fuel coming out of the first injector o-ring thanks to a leak (need to replace the o-ring)
Biggiesacks- Has about 1/2 tank. (6 month old fuel mixed with seafoam and I put in 3 gallons of new 93)
joseph143- I disabled the immobilizer already (f91 periphery, correct?)
Initially it hard starting issues I would mess around with the terminal connections and then it would start. When it wouldn't start it'd flash the green car with a key symbol on the dash. I'm assuming thats the immobilizer code. Since I disabled it, that symbol hasn't came up. I'll try resending the flash over to see if it makes any difference.
Checked the CAS harness (ignition in "on" position) and I had a solid ground connection and both 12v/5v readings as well. I'm guessing the CAS just went on me coincedentially.
I didn't pull the wiring harness to check for shorts but isn't that pretty much ruled out because of testing with the ohm meter now? I mean I shouldn't assume but I don't want go waste time either. I'm just going to order a new CAS and take care of timing while I'm at it.
Okay so I found the problem, my balance shaft belt disintegrated, bent my CAS trigger, and severed the bottom of my CAS.
I noticed that the countershaft balance sprocket rotates but it doesn't spin too freely. Should I be worried that a bearing is toasted? That might be why my belt tore, but at the same time all the previous owners never changed timing components and there's 116k on the car.
Evonick26
16
May 17, 2016 05:51 AM
