My Evo 8 will not idle.
I got a 2003 Mitsubishi Evo 8, I just got it about a month ago and its already giving me problems. When I start it, it will take a while for the motor to completely cut on, but as soon as the rpm's start coming down, it wont stop and the car shuts off. It will idle at about 0.5 Rpm for a few seconds and then the car shuts off. Maybe its a bad fuel pump? Someone tell me whatsup with it please.
Yeah I get a check engine light
Engine mods:
Injen full intercooler kit
272 cams
AEM adjustable cm gears
upgraded hotside to 10.5
tanabe turboback exhaust
turbosmart hybrid BOV
Mishimoto radiator
and tuned on 26 psi
Odometer is sittin at around 188,251
Engine mods:
272 cams
Mishimoto radiator
and tuned on 26 psi
I wonder if something is up with the tune...
Desired ISCV intial step position with AC off-Neutral
Desired ISCV intial step position with AC off-Drive
Desired ISCV intial step position with AC on-Neutral
Those values could possibly be part of your problem in your tune unless you can confirm the car did idle properly after the tune was completed.
Possibly massive boost leak, all that unmetered air although I would think you would be complaining about more than just idle if that was the case. Could be many things, as others stated, get the codes write them down. Then clear the codes and start the car. Let it idle for a few and recheck for codes, if a code comes on right away you need to get that issue resolved first.
FS[Northeast]: 2003 Evo, Reliable Daily Driver (Ohio)
EVO TYME!
For Sale - Cars For Sale
Oct 24, 2014 07:14 PM
newpassport
Apr 3, 2014 05:04 AM
jason42003
Jan 20, 2014 12:34 PM
