Possible purchase: 06 Evolution ix mr with 2.3L Stroker motor. What to look for?
Hi guys,
I am a noob when comes to Evo. I came across this low mileage 06 evo ix mr w/2.3 liter AMS stroker. Approx 65k miles on the chassis, and 30k on AMS 2.3 liter short block with stock heads. Stock exhaust and cat. The owner told me that it was last dyno @ 300+ whp. What should I be inspecting and to look for when I inspect the car? I would be highly appreciated if any fellow members could point me to the right direction. Thanks very much, and I hope to be more actively involved once i acquire the mr.
The owner returned exhaust to stock for smog purpose. 300whp is low? Wow, I thought that's pretty damn good for a stroker motor. Lol, that tells you how little I know about the evo's. What things should I check for during visual inspection? During test drive?
I bet the average Evo hp level is over 325whp on stock block. My 2.3 will see a modest 500 once its tuned lol.
Check for how hacked up parts and what not are or arent. If the car looks like a 16 year old installed them the chances are its true. The drive ability is another huge indicator how good the tune is, check how the clutch engages. Check AFR's while in throttle if he has a gauge. Receipts of builds, parts, etc. EVERYTHING you can think of lol
A stock evo makes around 260 from the factory. with a stock 8 turbo on a stroker and low boost and would be around 300+. So it could not be a red flag. many thing come in to play such as how boost being run. i would take this is on pump 91 octane so lower numbers right off the bat. if you can find a good evo shop. i would have them drop the oil pan and check the barrings and also check the oil for any metal Flake. I would also drive make sure the clutch is not hurting and the trans does not grind. or if you have the money and you do buy it you can just get the pull the motor and send it out to ams and have them freshen it up
Thank you for the replies guys. I think he's on a stock evo 9 turbo with stock intake or what not. Not sure how many pounds he's running. He mentioned it has already been tuned, so 300+ whp sounds pretty right on the spot for stock turbo with oem dp and exhaust. Will the dipstick be able to tell me the health of the motor etc......?
No one has said it yet, but I would be concerned why the engine was re-built at 30k miles! Was the previous owner beating the **** out of it? Bad tune? Just because they were rich and wanted a 2.3 lol? This would lead me to also be concerned with drivetrain parts, as people love to beat the crap out of these cars. Does the transmission shift smoothely in all gears? Is the transefer case whining? I just inturpet it as, if someone could blow the engine at 30k what does the rest of the powertrain look like! These are expensive parts to rebuild, so make sure they are inspected closely.
I agree, 300hp on 2.3 sounds a little strange with IX turbo, but maybe it is very de-tuned or VERY low reading mustang dyno?? Something that needs to be looked into, but not a reason to completely avoid the car. For the mere fact that you are not well versed in Evo's, I would HIGHLY recommend you bring it to a shop that specializes in them to look over the car. Spend a few extra dollars now to have it looked at, instead of spending thousands later when major parts start to fail. Goodluck!
Edit: At the bare minimum, perform a compression test and preferrably a leak down test to determine the health of the motor. The dipstick is not going to tell you anything unless the motor is already blown apart and there are hunks of metal in the oil lol
^ it sounded strange before because when I hear 2.3 I always think there is at the very least an fp red bolted to it, along with all the other supporting mods.
Stock ix turbo, intake, exhaust, etc. On a 2.3 just means there is a lot of untapped potential there. But I'd still have it looked at.
I would not buy any Evo without a pre-purchase inspection by a shop that knows Evos well, period, ESPECIALLY a built motor. My car with stock block, stock cams, stock turbo was making more than 300 whp on 93. Does it still have a 6-spd transmission?
WAAAT? It wasnt rebuilt at 30k, he said it has 30k on the build. Which is a lot on a built motor depending how it was used. I made 325 on a mustang dyno with my stock Evo 8 (cams/exhaust/intake) wittle Evo 8 turbo and pump gas a few years ago. That thing should be making all of 350-375 even on pump gas with those mods. All these guys suggestions are good idea's especially having a reputable shop look it over and doing a compression test.
