Air Filter Question
Old Mar 7, 2014 | 05:39 AM
randomdriver's Avatar
Air Filter Question
I am curious about what is a nice decent intake or air filter. I have weaponR and was told the air filter is restrictive. I have no clue what is the difference between a restrictive and non-restrictive. If anyone can help answer this question I would appreciate it. Also any suggestions for air filters would be awesome. Thanks in advance.
Old Mar 7, 2014 | 06:06 AM
EatSleepBoost's Avatar
Do some searching.
https://www.evolutionm.net/forums/ev...t-results.html
there is the biggest thread on here about filters. that should get you started.
An air filter should not be restrictive period. An engine is a big air pump. The more air in the more air out the more power. No time ever would you want to choke your engine of air.
Old Mar 7, 2014 | 06:38 AM
egis's Avatar
i suggest to buy maf adapter and k&n filter,vibrant etc.its cheap and effective.
Old Mar 7, 2014 | 04:20 PM
adriano_917's Avatar
Get an Amsoil dry filter its better than K&N
Old Mar 7, 2014 | 08:20 PM
TommiM's Avatar
How much power are you making or are planning on making? The oem intake isn't really restrictive until you start pushing over 350 hp, then maybe I would start to consider a better intake. Drop in aftermarket filters for the oem intake don't do much either btw.
Old Mar 7, 2014 | 08:31 PM
LAN_EVO's Avatar
+1 oem is damn good up to about 350whp just add a drop in filter and makes a better idle and just drives better overall. Only real reason to upgrade is if your making decent power
Poltergeist
Lancer Engine Tech
Jan 15, 2015 04:05 PM
leoni101
Mar 13, 2014 08:53 AM
Alfordz123
Sep 2, 2013 12:50 PM
kyoo
Jan 26, 2012 05:47 PM
RedLanEVO
Nov 26, 2007 07:34 PM
Quick Reply: Air Filter Question
