Torque Pro screen and hardware setups
I just got Torque Pro a few weeks ago and am trying to get the best setup for my 8. This got me thinking... Others on here have to be using it, right? How are you all using it? Phone or Tablet? How are you mounting your hardware? What gauges are you using? etc...
I purchased the app just to read and clear my ses. Played with it a bit, water temp, boost/vacuum, rpms, HP and torque. Its seems real laggy, shifting at 7500 would give readings up to 5500 rpms for some reason. It may need a GPS receiver to be more acurate
I've found it depends on the hardware, in terms of lag. When I run with my Nexus7, everything is pretty snappy. When I use my Samsung Galaxy Victory, it lags in realtime but the logging seems to be spot on.
I purchased one of these, but haven't recieved it yet, wonder if it will work?
http://www.banggood.com/HHOBD-ELM327...-p-913030.html
Is Torque Pro the best program to get (running on a Galaxy Note mobile)? Any free programs worth a try?
I had Torque free for a matter of 5 minutes then I pulled over and hit buy for the pro version. I really haven't messed around with any OBDII apps yet since Torque is really doing it for me!
No I haven't got it yet, Banggood is cheap but postage is frustratingly slow, I'll report in when it shows and I get a chance to try it out.
You can change from metric to standard in options. You have to figure though, the HP is calculated through the setting in your profile and actual GPS speed. Let's say you're going up/downhill, that just adds/subtract resistance just like adding/subtracting weight. I would say that feature is pretty useless.
ImEv0
Mar 21, 2014 01:57 PM
tscompusa
Nov 14, 2013 01:43 PM
Svendiesel
Aug 16, 2013 01:22 AM
CO_VR4
Apr 6, 2011 08:48 PM
Tony@hzmachineshop
EvoX 'For Sale' Electronics / Lighting / Audio
30
Aug 25, 2009 08:31 AM
