help with evo9
help with evo9
evo9 has straight pipe with missing ingen setup.. no maf and o2 sensors.. just got the car.. wanting to go oem... best way to retune and should i get the ingen setup or oem?? dont want to rice out...
Please type in complete thoughts and sentences, it makes things much easier for others trying to help you. If you are wanting to go oem and not rice it out then browse these forums and vendor websites for the missing parts you need. If you plan on doing any modifications then buy upgraded aftermarket parts now instead of oem.
ok.. got evo9 and has missing intercooler, piping, air cleaner, mass sensor,... previous owner straight pipe through(which is still on vehicle).. does not have O2 sensors.. best of my knowledge had arc air box and cooler... should i go back with aftermarket? i rather go back with OEM, but may consider decent aftermarket for the money.. ill pull engine codes tonight and see where to start i guess... if its been tuned then guess ill be lost from there or send to tuner shop to retune to factory specs for mass/O2.. thanks
thats my plan..guess i need to get some posts out fast... what would be a nice bov for stock setup for the money?? can i get bigger cooler but use factory piping and airbox?? or will it throw map/mass codes? thanks
Wow...still confusing.
Like MechTech said, do us a favor and share with us your ISSUES. We can't help you if you don't share with us what is WRONG, BROKEN, LEAKING, etc.... We know you are missing stuff....car will not run with the listed missing stuff. Find the missing stuff, get it running and go from there....
What is the point of pulling the codes if you are missing the intercooler, piping, air cleaner etc....???? You can't even start the car and who knows what additional codes you may pull once you get it running again.....
EvoM Community Team
Sorry dude, we delete useless posts. People try and post ***** their way into the marketplace all the time and we don't support that activity.
You can run a larger FMIC with the OEM piping and the OEM airbox, but you will need to retune the ECU A/F maps to get the most out of it. Parts that mess with A/F are best to run when tuned. You would probably be fine with a simple FMIC swap, but some parts need more fuel which can lead to detonation.
The MAF is part of the intake system, so changing the FMIC will not throw a code for the mass air flow sensor.
so best way is keep it stock or throw some good money into it.. guess thats what happens when you buy wrecked evo and someone takes everything off... everything looks original on this car but exhaust and intercooler/intake.. found previous pictures and had that arc but dont know what they done to it... everything else looks original... cant wait to get this fixed...
thanks for help guys.... this my first evo9 and kinda hard to determine whats previous owner done... ill throw everything stock and go from there... post picture when car complete.. had gauges in car but gone too... but if it is "SD" wonder if it been cammed.. if SD hope tuned good... well ill find out and know once i get it stated.. just you evo fanatics probably know more... just trying to get much info as i can.... thanks again..
