stock or 280cams ?
stock or 280cams ?
hi. im installing 3071 spec turbo from turbolab, i have gsc 280 cams, im wondering if i should run stock cams instead ?
because im running stock valvetrain.
what do you think is best option?
stock block also.
stock block also.
If you're going to stay with the 280's stronger valve springs are always recommended. A lot of people get away with 272's on stock heads, but just to be safe I'd recommend installing bigger springs for sure. Stock vs. the 280's though it all really depends on where you want to make power.
😬 that sounds like a recipe for some valves to float on you. I agree with the other guys on here. I ran 272's on stock springs but when I went to the Cossy M3's I upgraded the springs. You need to upgrade those springs if your running 280's.
voodoo-wrx
11
Sep 11, 2015 03:50 PM
