Amsoil Dominator racing 10w30 or Eneos 0w50?
Hi it's my first time here, glad to know there's a lot if evo enthusiasts like me. Okay, so I have been using the regular Amsoil 10w30 . I have been told that my next oil Change, which is a couple of hundreds of miles away, I should change my oil to any of the two mentioned above to "Max out" my Evo IX's performance. I'm a newbie when it comes to these things so bear with me. I appreciate all the answers and suggestions. Thanks Guys!
any mods to the car or is it stock? if you are stock or just a few bolt ons then stick to what your using or even whats written on your oil cap. If you are running higher lift cams then its a good measure to consider something with more zddp (zinc). Keep in mind that running oils with higher zinc may be detrimental in the long run to your catalytic converter though.
I have only one experience with Eneos and I didn't really care for it. It made my topline lifters really noisy at idle. I have a video on here of warm idle between amsoil zrod and eneos. To be somewhat fair, the eneos is likely to be on the thinner end of a 30wt oil. It drained out with the same consistence that Penn Ultra 10w30 did when I tried that, and that oil is on the thinner end according to my UOA.
I have no beef with that oil, I think my motor just likes slightly thicker oil.
TommiM
410
May 26, 2022 08:41 AM
MR. EVO MR
679
Dec 1, 2016 05:14 PM
boomn29
94
Aug 29, 2012 01:04 PM
