Evo 8 Shakes while braking no idea
Old Apr 1, 2014 | 05:29 AM
VRP's Avatar
VRP
Ok the car shakes while braking anything over 60mph...feels like it's in the front as the steering wheel shakes some, but its violent vibration through the whole car. Car rides smooth until you brake, wheel bearings feel fine also.
We just put brand new rotors and pads up front...still does it! Any ideas
Old Apr 1, 2014 | 05:53 AM
Ridge727's Avatar
Rear rotors......they are warped. I just fixed the same problem on mine. After turning the rear rotors it was smooth as glass...
wkarl's Avatar
Have you checked the inner/outer tie rods and lower ball joints? Check for play coming out of the steering rack as well.
A shake through the whole car could manifest itself through problems in the rear suspension ball joints/bushings as well.
Old Apr 1, 2014 | 06:03 AM
Ridge727's Avatar
I agree, def check those areas first. But the most common cause for a full on car shake or vibration at higher speed braking comes from the rear rotors most of the time. Like I said I just had the same Identical issue. After turning the front rotors, most if not all of the steering wheel shake was removed, and all that was left was the car shake at high speed braking, turned the rear and all shake and vibration was gone.
Old Apr 1, 2014 | 06:18 AM
grillpt's Avatar
Did u bed the pads properly?
Old Apr 1, 2014 | 06:21 AM
VRP's Avatar
VRP
Pads were bedded yes, turning rear rotors today will let you guys know.
Old Apr 1, 2014 | 07:48 AM
vtec fever's Avatar
Warpped rotors
You have wrapped rotors I would take a guess n say it's your rears rotors, if u can.
Old Apr 1, 2014 | 07:57 AM
kaj's Avatar
kaj
sounds like pad material left on the rotors. most people call them being "warped". i'd have the runout checked and go from there. that's the easiest place to start and most common as well.
Old Apr 1, 2014 | 01:01 PM
slowsrt4:('s Avatar
sounds like warped rotors to me. good time to upgrade
Old Apr 1, 2014 | 09:37 PM
OldManQuentin's Avatar
There are drilled and slotted rotors at lancershop for ten dollars less than leshwab charges for oem rotors...
Old Apr 1, 2014 | 11:21 PM
MR. EVO MR's Avatar
If it is the rotors don't turn them.
By cutting them your risking more warping down the road.
Just do several high speed stops and re-bed them again.
Easy fix!
Old Apr 1, 2014 | 11:24 PM
VanduzerWilliam's Avatar
warped rotors +1
Old Apr 2, 2014 | 12:21 AM
bestfromnw's Avatar
does it shake at all while driving at speeds over 50? if it does could be balance of the tires
Old Apr 2, 2014 | 04:04 AM
VRP's Avatar
VRP
Got the rears turned brakes smooth as glass, no more shakes! Awesome
Old Apr 2, 2014 | 07:21 AM
kaj's Avatar
kaj
next time, just clear the pad material. turning is not necessary and you end up cutting away valuable metal.
Quick Reply: Evo 8 Shakes while braking no idea
