Unusual noise
Unusual noise
I recently cleaned my MAF and re gapped my spark plugs. Now when my car is running I can hear a faint high pitched noise. It sounds just like that noise you hear sometimes after being exposed to loud noise. (ears ringing) it stays constant but dips a bit when the idle does. I can't tell exactly where it is coming from, but I can hear it while inside the car. Any ideas what it could be?
Car has:
Injen intake and IC pipes.
Forge WGA
Sheptrans 5 speed
AEM 380lph fuel pump
No tune
Car has:
Forge WGA
Sheptrans 5 speed
No tune
Sounds like you are getting electrical feedback. It's no coming from you radio speakers by chance is it? You may need a stethescope and listen around under the hood to try and locate it if you can confirm its not from inside the car. Does it do it with the key on too or does the engine have to be running? Maybe air whistling from your intake?
I know the relay for my aftermarket instrument cluster overlays has a constant high pitch noise. It becomes more pronounced the brighter I set the overlays (more voltage?). Not sure if that helps, but perhaps you have a relay going bad.
I have Tinnitus, so I know exactly what kind of noise you are talking about.
just a neon
11
Mar 29, 2007 06:55 AM
