hey guys plz help my engine broke
Old Apr 3, 2014 | 01:31 PM
mr evo7's Avatar
Hey guys ok I got this map from my tuner.
I have a 2.3 stroker 9.0.1
PTE 6262 (0.82)
The car started burning plugs right after it got tuned then a exhaust valve burn.
We opened the engine and all the cylinder bores seem to have scratches
This tune was done on 95 octane pump fuel with about 17psi
Could it be the tune that caused the motor to break? Please help
Old Apr 3, 2014 | 01:40 PM
xXANCHORMONXx's Avatar
Looks like a lot of timing to me.
Ask this to be moved to the tuning section.
Any pictures of the cylinder walls?
Also did the spark plug tips break off?
Old Apr 3, 2014 | 01:46 PM
mr evo7's Avatar
Yes the plug tips burnt and broke off
Old Apr 3, 2014 | 01:58 PM
Those are from the spark plug tips bouncing around then.
I think your due for a good remote tuner.
Old Apr 3, 2014 | 01:59 PM
sujinX's Avatar
when the motor was built, has it ran fine before this tune?
or was this the break in tune that did it in?
Old Apr 3, 2014 | 02:22 PM
mr evo7's Avatar
This was a low boost map that got tuned the same day the car broke
The break in tune was done awhile ago.
Car has done about 650 miles on break in tune with no problems at all
Old Apr 3, 2014 | 02:31 PM
desiromeo812's Avatar
Looks fine to me.. just needs more boost and more timing.
EDIT: and stronger spark plugs.
Old Apr 3, 2014 | 02:40 PM
CammedEvo's Avatar
Yes the tune broke the motor.
The car was detonating badly causing excessive heat, the heat transfers into the piston and causes it to expand. When it expands it starts to damage the cylinder walls.
FWIW I attached an example of how the timing map should've looked. (Pattern, not number wise)
Attached Thumbnails hey guys plz help my engine broke-screen-shot-2014-04-03-1.39.20-pm.jpg
Old Apr 3, 2014 | 03:03 PM
Ev0ikon's Avatar
That timing map looks crazy high. That and running high-z injectors with stock resistor pack, I say you do need a new tuner.
Dillond81
Lancer Engine Tech
Sep 28, 2015 10:44 AM
mini_moose
Aug 26, 2014 09:13 AM
mr evo7
26
Mar 27, 2014 06:41 PM
9!'clipseDOHC
Jan 6, 2014 07:21 PM
ApexSilverXGSR
Jul 17, 2010 05:11 PM
