gauge cluster help
gauge cluster help
hey guys can someone help me out I took out my gauge cluster to take the plastice caps off my bulbs to make the gauge cluster brighter and now the gauge cluster does not turn on all the snesor lights do but not the rpm bezel or speedo any suggestions??
Check to make sure you re-installed the bulbs securely and the connections are good and tight. I made this mistake before. Nothing wrong with bulbs. Or like mentioned above, they may be bad. Sometimes just moving them by taking them out is enough to break the connection of the element in the bulb if they were weak to begin with.
awesome thanks this worked ordered the LEDS as well so they are brighter
yes swapped the and the working ones did work in the socket so ordered new leds
usmcmarine915
Feb 17, 2016 04:38 AM
evoland
Mar 11, 2005 05:59 AM
