Popping under WOT and no power...
Recently installed a double pumper, and seem to be having a fueling issue I cant resolve. I have replaced the FPR, had my injectors sent out and flow tested. Double pumper double checked and Im sure the 2nd pump is activating. Idk what else to check. I have a Buschur Double, stock lines, FIC 1450's and on E85. Last thing I can come up with is I have gotten some bad fuel? Car has been boost leak tested and fresh plugs, Im at my wits end... Any input is outrageously appreciated... I can attach a Evoscan log if someone can tell me how?
Tom is tuning the car, gap was .017 per tuners instructions. I'm gonna pull the plugs and COP today and check things out. I had installed a FP gauge and on the first wot pull it pegged and 100psi and stayed there. I ordered another sender and it did the same thing? I don't wanna keep buying senders so I was trying to figure the issue out before replacing again.
Since it hasn't been mentioned. Have you checked Cam Timing? Perhaps you skipped a tooth somewhere. Also if aftermarket cams where installed did you have them degreed?
