Evo9 MR Help
I'm new to all of this, I'm learning little by little. This would be my first car that i work on. So any advise you have would be a big help, thanks.
well first thing i did whe i got my evo i did all the maint. water pump, timing belt w/kit, thermostat, spark plugs, wires, and flushed every fluid and i mean every fluid from power steering to diff. So I suggest do all the maint. first before you mod it, so you know the is gonna run on its full potential and you know everything was done instead of someone telling you it was done, but like the guy above me said check the stickies they will help
I have an EVO IX, never drove an evo 8 but mine has the works. Cams, bigger fmic, tbe, injectors, stock IX turbo. It makes 420whp on e85 and 390whp on 93. I dont see ever needing more than this for a street car. Spools way faster than my suby did too and is a hoot to drive.
here you go OP
https://www.evolutionm.net/forums/ev...uantities.html
also search around what fluids you want to use or the car there many option oem, redline, amsoil...i use amsoil on both my cars
EvoIX MR has better tolerances in terms of the engine being built so 10% less oil consumption. WAY better OEM cams, so way more power over an VIII with stock cams. Obviously the Evo IX Turbo makes more power, and of course the MIVEC.
Other than that same car basically.
here you go OP
CrackWoo
Dec 30, 2012 04:22 PM
rlevo
18
Jan 5, 2006 07:44 PM
