Engine RPM problem? :helpme:
Hi guys, I was driving the VIII RS just now, and I was on third gear, 5k rpm. When I step on the clutch wanted to change to 4th gear and I realized the rpm stays on 4k and not going down at all. I wasn't on the gas, and even I tried to rev it, the rpm still stays on 4k. So I turned off the engine, restarted it and it is fine now....
Any ideas what happened guys? I got the car not long ago, it was sitting in the garage for a long time. It is on OEM map now with OEM exhaust cause I need to get it somg.
edit: I havent bring the rpm to over 5k until this problem happened. I got the car not long ago, it has some mods and I need to pass smog.
The engine light is on due to it used to run different maps and tuning, I need to drive the car a bit to get it reset.
But I am more concern with the engine rpm problem now
clanzkiller
24
Jun 15, 2014 03:33 AM
titaniumkingpin
Nov 9, 2004 12:28 AM
