Evo 9 Timing belt MIVEC cam gear
I am in the process of setting the timing on my 9. The head was removed and the oil pressure is off so the intake cam gear spins free through the mivec range. While setting the position of the cam gear to the valve cover notch, should the cam gear be all the way anti clockwise or clockwise ? I hope this question makes sense.
I set it at default and lined up the cams with the valve cover and now Im having an issue with the cam slipping a few degrees at certain points. see video right around the end of the video, you can see the cam slip and hear the snap. any idea what it could be ?
FS[SouthEast]: Mivec Cam Gear
hutch959
10
Nov 25, 2016 05:35 PM
FS[Northeast]: MIVEC evo 9 Cam Gear
Freddy302
Jul 4, 2016 02:34 PM
