over heating issues
will rebleed the system today! i bought a mishimoto thermostat already. after i get that in and installed ill report back.
if it was te head gasket wouldnt i have milky rad fluid, over heating issues and misfire all the time...?
bought the car from my cousin. i bought it from him he wasnt in the market of selling it.
Not necessarily at all, people get over heating issues and show no signs of milky fluid that's only if your so far gone that the coolant passages can cross over into the oil passages.
A blown head gasket in just a coolant passage on the block will allow air and heat to get in while it's running, check your coolant overflow usually it has air bubbles in there if that is the case
the new t-stat arrived thursday. i installed it this morning. gonna do a test drive will let everyone one know the results. thanks everyone for chiming in
Someone on here had a similar issue. It ended up being a wiring issue with the temp sensor for the gauge. They got water on the pins and when they cleaned and dried them all was fine again.
You have one sensor for the cluster, the other temp sensor for the ecu. You can get a scan tool, or use evoscan to see what the temp sensor to the ecu is reading. If that's fine then check the wiring and condition of the pins for the temp sensor to the cluster.
You can also look at the coolant values on evoscan and then also use a IR temp gun and point it at the thermostat housing. They should be somewhat close to each other, at least for diagnosing purposes. They will be close enough to at least let you know the sensor is working correctly or not.
CFMP RAblue
Dec 28, 2012 10:08 PM
