How to disable the AYC on EVO 9 ?
How can I disable the AYC on EVO 9 ?
On Evo X there is an ASC button and if you hold it for more than 3 seconds then it disables the AYC, but on Evo 9 there is no ASC button....
if you press it once, yes it disables only the ASC / traction control, but if you keep it pressed for more than 3 seconds it also disables the AYC !
There is no AYC on a USDM IX, only ACD. Is the EUDM model equipped with AYC?
I know, but the 9 I am talking about is EDM model, my X is USDM, I need to disable the AYC on evo 9 for a friend so he can do drifts with the car, because the AYC is not letting you to do handbrake turns how you want...
My understanding when trying the same is that when the handbrake is engage, It will go into open diff to prevent damage just like yogi_b mentioned. I also find it hard to do a proper handbrake turn on mine. Will follow this thread to see if there are any advise.
The problem with AYC is that it does not let you drift the way you want. I just want to turn it off, not the entire system, I need the center diff locked so it transfers more power to the real wheels and no AYC.
ILOVEBOV
Feb 4, 2013 07:46 AM
Tractionlimit
Jan 15, 2011 06:01 AM
delkat
May 17, 2010 08:21 PM
