Spark Tech COP is awesome! But one issue remains. (pics included)
Do yourself a favor and search the P0300 code on here. You'll return thousands threads.
It's likely not a true misfire whatsoever. Mitsubishi's answer to the issue was drivetrain harmonics. 2-3 Rom ID changes to try and combat the issue
Disable the P0300 code routine and never worry about it again.
1 Post
change your plugs often, this is a turbo car and no matter how good the tune it you should change your spark plugs regularly (3-5k miles) on these cars
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Yes, it'll sputter only in 5th gear, usually as im getting on the freeway. I'll go into 5th at about 55mph and accelerate using 0-5psi of boost and the engine will crackle/sputter resulting in not being able to accelerate when it happens. And then from this point on, the car will randomly misfire even when under very little load in 5th gear, sometimes even when I'm just cruising at going like 65mph or something.
FS[Northeast]: Rally Red 2008 Evo X 5-speed SSS package
nyc 93-2jzgte
For Sale - Cars For Sale
Jun 3, 2015 11:12 AM
RalliartN
31
May 6, 2015 11:39 AM
TommiM
For Sale - Miscellaneous Automotive
Dec 3, 2014 08:36 AM
EVOllie
Nov 4, 2013 07:03 AM
