Running no oil cooler...
Is it terrible to not run an oil cooler? I had an engine failure a while back and removed the oil cooler. I've been running without one and other than noticing slightly higher oil pressure nothing weird. Finishing a tune and was wondering if I should replace it with another stock one. I can't see paying a lot for the aftermarket oil cooler... Thanks
Stms oil cooler isnt that expensive, but daily driving the car with no oil cooler isnt the best idea. Ive seen track evos do it and it works fine because they need oil temps to come up rather quickly. I have my oil cooler, i daily drive it, and see oil temps top out at 180-190 depending on the weather. I wouldnt want to know how hot it would get with no oil cooler
I drive a 335i and temps range 220-240. Although lower temps might be better. As long as you have full synthetic you will be fine. Just do earlier oil changes. Oil cooler would be a better choice.
kristian4802
76
Dec 7, 2021 07:04 AM
Profoxcg
10
Nov 15, 2007 09:20 AM
