Can I remove turbo through the bottom?
I was able to (with the radiator and intake pipe out) disconnect the o2 housing from the exhaust and turbo from the manifold and carefully shuffle it right and pulled it out the top with the manifold on
So if I remove the radiator, as I suggested, is there any reason to also remove the O2 housing?
I would rather not.
The radiator needs to be drained either way.
Removal is 5 minutes.
Dropping the turbo down with only 4 bolts removed, is easier than breaking 10 Manifold bolts.
I will remove radiator because its a beautiful PWR that I will not damage for vanity.
I would rather not.
1 Post
yes you can but you will need to remove the downpipe which is a pita with the 2 bars that must be removed. it is easier to take the manifold off and the whole shabam. Make sure whatever you do, remove the radiator
kozmic27
Evo X How Tos / Installations
32
Oct 28, 2019 04:39 PM
halfnhalf83
31
Oct 7, 2015 08:23 PM
jeffpinto
Mar 21, 2015 03:27 AM
Vivalaevolucion
Jan 2, 2005 06:06 PM
