Wot 2nd gear around 4-5k rpm sputter and rpm goes down
Old Jun 26, 2014, 12:14 PM
GearJamminMR's Avatar
Miss fires and bad coils generate codes, so either your ecu was reset (power disconnected) or you have some other issue. You didnt answer what PSI you tested it at, many leaks only happen at higher levels. I believe testing to 30psi is standard for most shops. Your gap is a huge red flag. Factory manual calls for .7-.8mm so right there is a huge problem.
99% of the time ignition faults will set a code I agree with that but even with my problem it did not set a code. My misfire was only happening at around 60+% throttle only, other normal driving was perfect and the only way I found the misfire was watching the misfire counter data on my scan tool. Again this time it did not set a code. But replaced the spark plugs, ohm tested injectors and they were good so left one other option, got new coils and problem solved. Now there is ohm testing you can do in the coils to fully condemn them bad.
Old Jun 26, 2014, 12:20 PM
Also agree in the gap issue. I would hope you meant .025 in, that would be fine. But if you meant what you typed of .25 mm then yes biggie is right that needs changed.
Old Jun 26, 2014, 12:38 PM
Biggiesacks's Avatar
Im not saying it isn't the coil. It very well may be the ignition coils are faulty, but there are many other things it could also be. Troubleshooting is a methodology and you have to cover the basics before you start delving deeper.
I never claimed that i could diagnose the problem with those 3 questions. The answers to those questions though are the first layer of the diagnostics, and you need the answers to know how to proceed further.
Old Jun 30, 2014, 08:14 PM
Igaly1021's Avatar
sorry guys i meant .025 but i solved the issue, it had bad coil boots changed both boots car is running great again. thanks for the advice guys
Old Jun 30, 2014, 10:23 PM
glad to hear you fixed it! I also had to replace my boots/wires a while back. Ive been eyeing a C.O.P. setup since my coils are kicking 140k miles on them and im sure they are getting tired.
Old Jun 30, 2014, 11:54 PM
CT9A PR's Avatar
Seems like coil or poorly gapped spark plugs
Old Nov 7, 2015, 05:18 PM
RAC
RAC's Avatar
Hmmm
Just started having this issue at 5th gear around 3,000 and up but fine at 6th. Need to know more
TariqEvo
20
Nov 12, 2017 10:00 PM
Evoxnoob123
Sep 1, 2017 11:02 PM
papabeardoe
Jun 13, 2017 04:06 AM
Rasperin
May 8, 2017 06:11 PM
2006GSR
Aug 20, 2016 09:22 PM
Quick Reply: Wot 2nd gear around 4-5k rpm sputter and rpm goes down
