evo 9 head gasket causes lower compression?
So I have a friend whos looking at an evo and since I own one hes been asking me what to talk to this guy about.
The car had a new shortblock put in with an evo 9 headgasket. However when I found out the compression numbers its 120 across the board which would normally be a sign of an engine rebuild being needed in the near future. Since its stock specs in the motor I thought it would be 160 +/- 15 across the board.
The guy who owns the car said that the evo 9 headgasket will cause a lower compression but I just wanna make sure my buddy isnt getting screwed.
Cheers
Colton
Cheers
Colton
Don't forget you're in New Mexico at higher altitude. Your compression readings will be lower, not neccasarily that low. For example I'm on stock block with built head and gsc s3 cams. My compression is 140 across the board. I did a wet test and compression jumped up 5psi each cylinder. So the motor is good. I'm also in New Mexico. What cams does the guy have if any? Also do a wet test to see if there's any variance.
Yes you're right, this could be a red flag but theoretically an Evo 9 headgasket is thicker than an 8. So that could cause lower compression correct? That's assuming he put a 9 gasket on a 8 motor. Either way as a buyer I would do a dry/wet compression test and a leak down if need be before I look into anything else first. I wouldn't let this push me way from the car if the wet/leak down test checks out.
Don't worry about the numbers. Do a dry/wet test and a leak down test. If the numbers are within tolerance it's fine. What compression tester are you using? Is it old? Different compression testers will give different results. Like biggie said there's a lot of factors.
EVIL_EV0
11
Sep 19, 2014 06:27 AM
overdrive1
Apr 11, 2014 07:02 PM
DanDan1320
Oct 10, 2013 07:57 AM
