run into Invidia o2 housing issue.
The only thing they mention is the Turbo XS
Well its the same pattern, however as you can see in my original picture. the Brass is too thin, making the two flanges just about to meet.
Anyhow, i thought id make an update.
Ive decided to ditch the Invidia o2 housing.
Im certain from judging by its appearance, that it can perform well.
However, the amount of issues i have trying to get it on. Ive lost interest.
Not that i am knocking the brand, but i thought id mention a few things on here, incase anyone in the future is looking to upgrade… they can search as reference.
Invidia O2 housing to fit the EVO IX requires:
1.) Extension of the O2 sensor cable. A cable extension is available for purchase. (sold separately)
2.) The brass donut can cause issues. Many here have found problems with it sealing. it is smaller than the stock donut and has caused issues to some people with aftermarket downpipes.
3.) There are a few ways to replace the o2 sensor. i managed to get the OEM o2 out, by only removing the radiator and lowering the down pipe.
(without splitting the turbo or removing the manifold)
Howebver, the invidia O2 requires to be assembled OUT of the car, with the exhaust side out of the car. The bolts can be tighter ONLY with an open end spanner. Sockets do not work on the nuts / bolts once they are in place (the due to the design/body of the o2.
Anyhow, thanks for all that has made posted and or made suggestions.
cheers
cheers
Just trying to help
The standard eBay ones have a 2.5-2.75 inch inlet which is stamped steel.
The outlet on the invidia o2 is 3 inches. Plus the brass donut so eBay, works, turbo Xs, Buschur and other similar ones will not work.
These are all of the downpipes I have tried.
Just trying to help
Just trying to help
Im going to order another O2 housing…
and hope it won't be one that requires splitting the turbo.
If the next one does, then ill be forced to.
Thanks for your support. Ill repost if i run into any other issues separately.
FS[West]: Socal Evo X Part Out
Don'tNeed6th
Aug 13, 2016 06:40 PM
FS[Northeast]: 2005 Evo VIII MR Track Car
4cdndctn
For Sale - Cars For Sale
16
May 16, 2016 04:49 PM
FS[Northeast]: NJ 2011 EVO X GSR OEM Wheels (Black)
milab21
For Sale - Wheels / Tires
Nov 23, 2015 01:50 PM
FS[West]: Do-luck Replica trunk painted WW
butters149
Aug 29, 2014 07:49 AM
