EF3 slow spool HELP 2
Old Aug 29, 2014, 06:38 PM
  #31
TommiM's Avatar
Originally Posted by DsmGuy86
Hey brother I think it was mentioned but I wanted to also shed light with this.
I had the "exact" problem with me ef3 a while ago I wouldn't make boost till 5500 rpm.. I ended up talking to Nate at map he had me send it in and turned out I bent a pin in the comp housing which caused me to lose preload. They fixed it under warrenty sent it back and now after 30k miles still running strong and doing work spools much much better now.
Hope that helps I'll try and find the emails between Nate and I for more info on what happened. Hope this helps brother
Do you mean the lever arm on the turbine housing for the wastegate?
Old Aug 29, 2014, 08:00 PM
  #32
DsmGuy86's Avatar
Here's one of the emails from Chris at MAP
Hi Jon,
It is a locating pin for the compressor cover to the bearing housing, essentially the comp cover rotated based on the force of the actuator causing the turbo to lose preload, hope this helps!Chris Carey - Founder & President
Modern Automotive Performance
Old Aug 30, 2014, 11:27 AM
  #33
black_beauty's Avatar
DSMGUY how old was the turbo when that happened? Mine is a week old. im gonna pull it off and get the big c-clip seated correctly and see where that gets me
Old Aug 30, 2014, 11:30 AM
  #34
DsmGuy86's Avatar
Hell I had maybe 2k miles on it and that's a stretch to be honest but it happened right after I was tuned on my toxic fab o2 dump litterly the night I got tuned I drove home woke up the next day and had 16lbs of boost lol
Hopefully it helps man if not give map a call they have amazing customer service and Mario brothers music when your on hold.
Old Aug 30, 2014, 01:52 PM
  #35
94AWDcoupe's Avatar
comp covers cant spin. they are pinned to prevent movement .
Old Aug 30, 2014, 02:30 PM
  #36
DsmGuy86's Avatar
Sorry the other email (not posted) stated the pin bent.. I'll find it give me a few
Old Aug 30, 2014, 03:08 PM
  #37
jfa_evo's Avatar
subscribe,, I'm waiting to install a EF3, which I know it's a bit laggy according to comments from different forums. BTW, Is the bottom end stock?
Old Aug 30, 2014, 03:14 PM
  #38
TommiM's Avatar
I wonder if this 'bent pin' issue has anything to do with the turbine housing issues they were having in the past
Old Aug 30, 2014, 03:57 PM
  #39
JFA, not a stock bottom end, it got the full treatment about 1 1/2 ago. I got the compressor cover correctly seated, no longer leaking and still the same thing. Boost log is identical. Im at a loss the only thing that hasn't been changed is the WGA. Its a turbo smart it has to be cracking open? that or could my timing be off but the car still pulls hard?
Old Sep 1, 2014, 07:54 PM
  #40
Bhsj13's Avatar
maybe you really got an ef4 and no a ef3. But, any updates?
Old Sep 2, 2014, 01:24 PM
  #41
If it was an EF4 I should be making more power...
Old Sep 3, 2014, 09:12 AM
  #42
Im at a total loss? could it be in how im logging? Im in vac til 2500 then I floor it? In 1st and 2nd running it hard, the car feels good.
Old Nov 17, 2014, 07:10 PM
  #43
Bhsj13's Avatar
yo, did you ever resolve this slow spool issue?
EVOII
10
Feb 25, 2016 11:09 AM
deathtracks
21
Oct 24, 2015 11:01 PM
vaflyboi757
21
Aug 10, 2015 10:40 PM
evotuner04
153
Apr 17, 2015 11:50 AM
DsmGuy86
Oct 1, 2012 03:02 PM
Quick Reply: EF3 slow spool HELP 2
