EF3 slow spool HELP 2
Old Jul 1, 2014, 10:51 AM
black_beauty's Avatar
Having a slow spool issue with my EF3 and cant figure out the problem. I have changed all exhaust gaskets, boost leak tested several times, taken the turbo apart and checked the flapper (nothing visibly bad), and the turbo spins freely. I don't know what else to check. On built 2.0 on e85, S3's, SD, megan manifold :/ and ebay o2 housing. Hybrid boost but even on WG pressure alone spool is slow. Any help is appreciated, Thanks.
Old Jul 2, 2014, 03:55 AM
slowsrt4:('s Avatar
have you considered switching to an FP red? but on a serious note, take a log and post it to shed some light to the issue, your EF3 is not going to spool like a stock turbo.
Old Jul 2, 2014, 06:33 AM
Im aware it wont spool like stock, but not having 20psi by 5k something is wrong. My tuner is telling me there is a spool issue, this isn't me just missing my stock spool lol Ill try to take a screenshot of VD and post it
Old Aug 26, 2014, 02:41 PM
zombie mode thread, dafuq is wrong with my car? BRAND NEW ported EF3 comp&turbine, 5k to get to 20psi... new gaskets. No boost leaks. Did a cam install a while back...Out of time, cracked mani? Im going nuts!
http://i961.photobucket.com/albums/a...psa84172f0.png
Old Aug 26, 2014, 02:58 PM
xFonts's Avatar
You sure your DV/BOV isn't leaking? Checked axial play as well?
Old Aug 26, 2014, 03:02 PM
no boost leaks, check SEVERAL times with a spray bottle. axial play? as in shaft play? This turbo is BRAND NEW! 50 miles! No shaft play, spins smoothly
Old Aug 26, 2014, 04:57 PM
Bhsj13's Avatar
wow, looks like 35r or bigger type dyno graph. i hope you figure this out.
Old Aug 26, 2014, 05:11 PM
meckert's Avatar
your turbo, and cams move the power band far rt....and my guess is you have the cams retarded to max HP or at the very least not advanced. Thinking too much cam and almost too much turbo making for a sluggish midrange--one thing you didn't provide is exactly how much psi you are making at full boost and what the rpm its all in....apparently its not at 5k. Pls advise.
Old Aug 26, 2014, 06:26 PM
VD log is attached, post #4... 30ish max boost
Old Aug 26, 2014, 06:33 PM
meckert, I haven't done anything to retard the cams? stock cam gears. advanced timing in the tune yes
Old Aug 26, 2014, 07:10 PM
jdmdc2r01's Avatar
That log is on E85?
S3 cams will move the powerband to the right but not that bad.
I think you need a better tuner...
Old Aug 26, 2014, 07:18 PM
yes E85, tuner I don't think is the problem...TSCOMP
Old Aug 26, 2014, 07:47 PM
jdmdc2r01's Avatar
Oh...I see, what did Tom say was causing the late spool up?
Old Aug 26, 2014, 07:57 PM
cracked manifold was right off the bat when I told him I had a megan. I visually inspected it thoroughly and saw nothing. I purchased the cams from him as he said they would help me out greatly over the HKS 272's I had. And I asked if I could have messed up the timing to have this issue? Cars pulls smooth and hard just slow spool. So I wasn't sure if I could have caused this. Cant remember what he said? Could my timing be off slightly and cause this but still pull hard? Ill get the timing checked.
Old Aug 26, 2014, 08:00 PM
06ebevo's Avatar
check the preload on the wastegate actuator?
running an mbc?
Quick Reply: EF3 slow spool HELP 2
