Best radiator fan for Koyo half size rad.
I m looking for a best radiator fan for my new Koyo half size radiator which just designed for drag use only. I don't know what size to go on it and the blades design.
AFAIK, most aftermarket slim 12" fans will work. So will the stock fan.
Something with a shroud will work much better than unshrouded:
http://www.streettunedmotorsports.com/parts/fal_fan.htm
For drag only id say a 10 or 12, would be fine. Blade design you definetly want straight as they will flow more than curved. Don't forget that depending on your turbo setup you may need to get a pusher fan versus a pull type.
evo209
Sep 23, 2015 09:37 PM
RallySport Direct
Vendor Classifieds
158
Jan 16, 2015 04:05 PM
evotris
Jul 6, 2014 10:01 PM
