evo churping noise, pls help!
Hey there hopefully someone can help me , I've linked a video of me revving my engine and there is a chirping noise coming from it(its an evo 6) , could anyone tell me what this is or could be ? thanks A lot!
I did spray the belt/bearings around the alternator and it goes away for maybe a minute then it's back . All the belts look completely normal tho hmm not sure what else it could be
I found where the noise was coming from exactly it's the pulley right next to the engine , I'm guessing I have to take the wheel and liner out to get at it hey?
Did you remove the pulleys from the car? If not you need to. Once removed you need to hold in one hand and spin with other, then make sure it spins nice and smooth. If that is all good then slowly turn making sure it doesn't hang up as you turn it.
briantorres1991
Dec 30, 2016 11:56 AM
botemarc
15
Aug 6, 2015 01:21 PM
