AEM UEGO reading rich
Old Jul 26, 2014 | 04:18 AM
dspize's Avatar
hey guys today I installed my aem wideband in my 97 evo 4 and started it up and its reading 10s 11s at idle.
this kit is brand new i installed as the instructions said. it surly couldn't be running that rich as the car idles fine. Tomorrow ill remove the sensor and test it with a petrol rag to make sure the sensor is not a dud!
Has this happend to anyone before?
I have searched and searched but nothing like what mine is doing.
any help would be great!
Edit - the uego sensor is fine i just went and test it with a gasoline rag works fine.
Old Jul 26, 2014 | 09:56 AM
superbovine's Avatar
Where is the sensor installed? Is it after any catalysts or mounted out of the exhaust stream in any way (oversized bung)?
Old Jul 26, 2014 | 03:51 PM
dspize's Avatar
I have no Catalysts and nope the bung should be fine its the one that came with the wideband kit.
Old Jul 26, 2014 | 04:44 PM
Weird. There isn't any calibration on these, perhaps you got a bad sensor.
If you key on with the sensor out of the exhaust pipe, does it go full lean?
Old Jul 26, 2014 | 04:53 PM
dspize's Avatar
yup it does i just tested the sensor in the air reads full lean put it in a petrol rag and full rich its starting to annoy me.
Old Jul 26, 2014 | 05:22 PM
Weird. You're positive you aren't running that rich? I've seen it before, it does happen. Your exhaust would be slightly irritating to your eyes.
Old Jul 26, 2014 | 05:24 PM
fantrman's Avatar
Maybe it is reading correct and you are idling rich. What does it show as you are steady cruising? If it shows ~14.5 AFR, it is probably reading correct at idle.
Also, does that gauge have a startup sweep? My analog guage does and will read off if I don't give it time to do its thing before I actually start the engine.
Old Jul 26, 2014 | 05:39 PM
That's a good point too. The AEM analogs do have to wait a few seconds after key on before cranking, and they need to be powered with a wire that is hot while cranking, else the self calibration will fail.
dspize's Avatar
yes it has an a start up sweep maybe it is running rich ill take it for a drive shortly.
its an evo 4 with evo 7 ecu running tephra v7 i wanted to get the aem in for a remote tune as where i live the closest tuner uses ecutek and charges $1395+ for a reflash.
Old Jul 26, 2014 | 05:41 PM
dspize's Avatar
what are you getting your 12v from?
Old Jul 26, 2014 | 06:24 PM
fantrman's Avatar
For constant power, I went directly to the battery terminal clamp.
nor11384
Apr 26, 2017 10:47 AM
ugakirk
Apr 29, 2012 01:57 AM
maradits
Apr 3, 2012 06:03 PM
catman78
Aug 20, 2011 07:17 AM
gvillevo
May 3, 2011 07:15 PM
Quick Reply: AEM UEGO reading rich
