Please help! Fuel pump issue
So I have an issue I cannot figure out. My fuel pump won't kick on.... I checked the power it's getting power ... It also is directly hardwired it's the AEM 320 .... So I checked all the fuses there all good,checked the relays all good, took the pump out and put it directly to the battery to my surprise it kicks on ...... So it works directly on the battery yet the power is also good threw the car but dsnt turn on when in the gas tank .... I'm baffled by this and could really use some help. Anyone else ever have this issue ...or have any input ideas to fix this
So it has near regular voltage at the hanger connector?
If the pumps not turning on Id suspect the connector that plugs into the top of the pump.
Not very common that those get disconnected but if youre seeing voltage at the connector to the pump hanger, but the pump is not powering on, the connector on the top of the pump has to be the issue. Unless its an issue witht he pup itself
You have to pull the entire hanger to access this connector
The hard wire kit it attached to the oem harness the relay stems off that power but it's getting power from those wires and that relay is kicking on so I assume that it has nothing to do with any type of wiring issue
Iv pulled the entire hanger out and ran the fuel pump directly to the battery it worked .... I also ran it directly to the hanger with the fuel pump connected and It barely kicked on .... Don't no if it could possibly be the hanger itself ? I bought a new fuel pump gna see if that works
And then the fuel pump has an external wire coming from the battery, going through the relay?
Id check the relay out, maybe theres some resistance in there causing an issue.
Theres not a whole lot to investigate here lol
Little late but wanted to say thanks for everyone's input.... Wound up being my CPS wire was loose and the timing belt chewed right threw it .... Back up and running and better then ever 👍
Pal215
18
Jun 11, 2017 10:47 PM
lSimplyMel
Dec 14, 2014 05:33 PM
EVO_RYAN
25
Oct 19, 2009 12:16 PM
