Aem digital boost gauge reads positive psi at idle!
Bought a 2008 evo x mr last year and found out the car had an aem digital boost gauge and a wideband installed in it unfortunately the previous owner left the wiring and sensors for both gauges but took the gauges.
The wideband is shot as driving it for 20k plus miles without any power to it has destroyed it.
I am having problems with the digital boost gauge as of now. Either my friends gauge is busted or the sensor the gauge connects to is busted. At idle the car reads positive 6 or 7 pounds of boost and when I barely get on it quickly goes up to like 32psi which is 7psi higher than what my car is tuned at. I haven't checked how the gauge is wired but I was under the impression that the digital gauge wasn't as touchy with wiring as the analog gauge. The T fiting for the vacuum line comes off the line going into the wastegate..
Any help would be great thanks!
1 Post
you would probably be better off just buying new ones. You don't want to go cheap on monitoring devices as if they are inaccurate it could cost you a motor..
Digital gauges are very sensitive to wiring issues. You can refer to AEM tech forums for a wealth of info. I have had three AEM digital gauges for about six years, and have had absolutely no problems. I checked out AEM's forums prior to installing the gauges, and I found that a lot of problems were centered around customers who used a ground wire shared by some other device. AEM advises against this, even to the point of recommending that AEM gauges not be grounded together, and have separate ground wires going to separate locations. This seems to be even more important (according to AEM) with the AEM digital air/fuel gauge.
I'm not an electrical engineer, so I can't explain why this is so. AEM does have electrical engineers, and I'll take their word for it. I have seen a fair number of posts here that argue that "a ground is is a ground." Maybe so. I won't argue the point. I have also seen a lot of posts over the years in which people have problems with an AEM digital air/fuel gauge which has been grounded in common with some other device.
I bought AEM gauges, and it seemed reasonable to follow their advice regarding the installation.
EvoScott95
Evo X How Tos / Installations
Sep 29, 2015 05:35 AM
FS[Northeast]: AEM UEGO Digital Wideband Gauge w/BNIB sensor
Illrunya
Jul 23, 2015 12:34 PM
